I've done some searching and it seems to be a massive no no. But I don't see why.
Before I start, the walls are very straight and the plaster sounds solid all around.
I'm redoing the kitchen and I want to fix plasterboard over the current walls. They are plastered (about 20mm thick) and wallpapered, which would be a massive pain to remove. I would rather just overboard them and tape and joint.
It is an old Victorian house with big skirting boards. It sounds extremely bodgy but they are big enough to where a 9.5mm plasterboard could sit on top of them, if fixed with screws. The plaster/brick wouldn't be taking the weight of the boards. I don't want to lose any space by battening. Dot and dabbing would require me to remove the wallpaper and skirting, which I definitely don't want to do as it doesn't seem necessary.
If I absolutely had to, I could remove the wallpaper, but battening or removing skirting is out of the question. I really don't want to lose any space at all.
Basically, I know it would LOOK fine, but I need to know why professional tradesmen are so against the idea? Would putting that many screws in damage the integrity of the wall or something?
Could I remove the wallpaper, use a grab adhesive, and use less screws?
Again, I know it's pure bodge and far below any reasonable standard of building, but I just need to know if it would actually cause any damage.
Thanks.
Thanks.
