My house has been heavily extended and I'm sure any professional electrician would have had a fit had he looked under the stairs: 4 separate consumer units (all with old style fuse wire fuses) and wires everywhere.
I decided to replace the whole lot with a modern consumer unit with MCBs.
I was happy with my work, I now have a single modern consumer unit with nice resetable MCBs on each circuit.
The total number of fuses is the same, and I've made sure to keep the ratings of the MCBs the same/similar as the fuses they replaced.
All is fine except for one problem - one MCB keeps tripping. Alas it's the ring that includes my study with my computers in. Who knows whether I'll finish writing this post before it trips.
The tripping isn't predictable. The ring is a ring that supplies the whole of the back of the house and had a 45A fuse wire before and now has a 40A MCB.
With the power on and off like a yo-yo I've had an opportunity to identify each and every item on this ring - and the total consumption simply isn't 40A.
The ring covers the immersion heater and 4 rooms. I've turned off the appliances in all rooms except the study (including the immersion heater) and the items I have on in the study all go through a 13A fused wall switch. When the 40A MCB trips, the 13A fuse (through which the only stuff in use is going) does not blow. So I know I'm not using enough to "blow" a conventional fuse - and of course I didn't have a problem until I replaced the old style fuse wire fuses with MCBs.
I've tried another MCB (admittedly a 30A as I didn't have a spare 40A, but again from above, I can't be using more than 13A) and the same thing happens.
Any suggestions?
Could I have a "noisy" supply? If so how do I find out?
Can an appliance trip the MCB without running over the MCB rating?
Given that the only thing I've changed is the consumer unit arrangement - is sparking possible inside the consumer unit - there's a little bit of bare copper wire on the wire connected to this circuit - but the spark would have to jump in excess of a centimetre if it was to short. Is this likely?
Any suggestions?
