Hi all
Can someone explain why i would need a room stat if all the rads have trv's fitted and the boiler(combi) has a built in bypass.
surely as the valves close the water would go round the bypass till all the rads are closed then the boiler would switch off as the water going through the bypass would be up to temp
Then as the room cools down the trv opens up water is pumped back through boiler senses cold water and fires
Thanks for any help
Robert
Thanks for any help
Robert
