- Joined
- 27 Jan 2008
- Messages
- 24,903
- Reaction score
- 2,877
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I can see how too high stops it working but not too low. Well in a way as soon as one reaches the point where it needs heating to maintain correct temperature well yes but if a freezer is set to -18°C and the ambient temperature is -15°C then one would think the freezer would have rather an easy time and there would be no problem.
However my freezer states minimum ambient temperature 15°C not really a problem but question is why should one freezer work at -15°C and another can't go below 15°C?
Is it something to do with the inverter control? I can see if the motor runs 24/7 and never switches off that it may not be able to run slow enough but my motor clearly does switch off.
In the past once a fridge/freezer motor started to run it would continue for an hour or more before it switched off the temperature of the unit was controlled by the mark/space ratio of motor running and static.
However the new inverter controlled unit will often kick in for just 45 seconds and I wonder why.
The unit seems to work well but would just like to get my head around this new technology and why an ambient temperature of 4°C to 15°C is a problem. OK below 4°C I understand it would need heaters to maintain the correct temperature but above 4°C what is the problem and why is it not a problem with some units?
