I'm adding a stud wall to a dining room to form a new study and walk in cupboard instead. While I have the floor up (I'm also insulating between the joists) I was planning on adding a pair of new sockets on the new stud wall.
However, when investigating a little more it turns out that the dining room isn't on the main downstairs ring - it's on it's own little circuit with a 20A breaker on the consumer unit (cable is 2.5mm). Stranger still it looks like the room was originally one ring - but one of the sockets has a cable cut where it enters the back box so now the room is composed of 2 radial circuits.
Why would someone do this? It seems absolutely intentional. Maybe the cut cable was damaged in some way and it was easier to turn it into 2 radial circuits? The 20A MCB does look like it was put in at a different time to all the rest.
I'm thinking I should get an electrician in to turn it back into a ring (and add the sockets), but curious as to why it would be like this?
