why have 2 drain cocks for CH
20 Oct 2010
Lanarkshire
Hi riend asked me to replace faulty rad valve and when i went to drain down the heating found 2 drain cocks right next to each other, this is on a build of around 10 years old is this a new thing
if it is a system boiler then one drain down for CH and the other for the HW cylinder, if its a combi then one for flow pipework and other for return not as common but good practice
System boiler with megaflow, but fernox in both pipes, all houses had them (had a quick check) up in wishaw
If it's a two pipe system then there should ideally be 2 drains - one at the lowest point of each pipe. Depending on system layout there may be multiple low points which should all ideally have drain points.
Of course, some installers pay lip service and may fit a notional drain point which doesn't really drain the system and leaves a lot of pipework still filled. And if your one of the numpties employed by BG to install the system in my mates bungalow (before he had it), it won't work because they'll have melted the washer while soldering it in :rolleyes:
Normally a good idea to have drain off 's on all drops or design it so the flow and return are put outside at their lowest point
Saves the hassle of dragging a hosepipe halfway across the house
There are a couple of points under our floors where there's a couple of old taps leading to an inconspicuous 1/2" tapped bush (with plastic plug) in the wall outside.
