Some time ago I was on here asking about opinions and experiences of unvented cylinders. Turns out that that option (along with any combi option) would be prohibitively expensive as I have since found out I have an old shared main in 1/2" which would need an expensive upgrade. I've not measured pressure and flow, but as someone on here said, many manufacturers don't recommend installing their products with such an incomer.
So, my only cost-effective/realistic option is for a gravity-fed hot water cylinder. Added bonus is that I should be able to DIY everything except the boiler and primary!
I've noticed that some of the hot water cylinder makers seem to be trying to steer people away from grade 3 copper cylinders due to safety concerns (although they're happy to continue supplying them ). So I've been looking for Grade 1 and 2 cylinders and not had any luck finding anyone who stocks a full range! Even the plumbers merchant here only does grade 3 or unvented.
Do the grade 3 cylinders burst under some fault conditions, or do they corrode out insanely fast? Anyone able to point me at some Grade 1 and/or 2 cylinders?
