I've copper pipework in a concrete floor that's been down approx 8 years. My oak floor started to cup/lift so I've dug up a patch of screed, down approx 5 inches to the pipe work.
The pipes were adequately wrapped in plastic backed felt, laying on top of the dp membrane with an off cut of membrane on top, followed by sand then screed. There are the cold & hot pipes and the 2 ch pipes close together. When uncovered the felt had turned black and completely soaked and smells of a stagnant pond. The sand also was very damp. Is this a classic leak or can condensation from the cold water pipe cause this ? Also if not a leak what can I do ? re run the cold above ground ? I think the wetness has travelled all along where the pipes run as the floor has cupped in line with the pipe run. Thanks in advance
