- Joined
- 27 Apr 2008
- Messages
- 9,670
- Reaction score
- 953
- Country
I was fitting an outside tap for a friend today, just putting it on the top of the pipe (everything else was already there) and lo & behold there was a mighty spurt of water.
Some plonka had used compression joints on 15mm copper pipe to supply an outside tap & it has all been buried underneath a new cemented in patio.
The joint was not even tight. (its a corner joint).
And even worse... it was BEFORE the main house stopcock so would not turn off. Luckily I managed to remove a slab & tighten it otherwise I would have had to turn it off at the street & that would affect the neighbours too.
View media item 13615
