- Joined
- 7 Jul 2015
- Messages
- 56
- Reaction score
- 2
- Country
I am just going through the process of reattaching my towel rail.
View media item 96754After I unscrewed the fittings used to keep the towel rail in place I noticed they were stuck to the wall with what appears to be silicone.View media item 96774
Why was this needed when it was already screwed into the wall? One idea might be to do with the fact its in a bathroom and they wanted to gain a water tight seal round the fitting. Is that a normal practice since all my other fittings in my bathroom didn't have this done to them? I doubt it would have been tough enough to provide any further structural support. Would they have been worried that the fitting wasn't flush to the wall since the wall plug extrudes about 1mm from the wall and wanted something to give it some extra grip?
View media item 96763
Either way I am guessing I should use the same method when reattaching the fitting back onto the wall. I presume I can do the same with white silicone as it will be camouflaged by the white wall behind it.
