I hope this is the correct forum for this problem. I have a wireless router that I want to use via the ethernet connection. When I connect the PC with the supplied short ethernet cable to the router it works fine. I laid a 20m CAT5e cable about 20m long and connected the RJ45 connectors either end. I wired terminal 1 to 1, 2 to 2 etc. This however does not work when I connect the PC to the router. I checked the cable with a LAN tester and it is fine.
Can anyone tell me why this won't work.
