Hello
Where can I get the schematics for a Wickes CDT212W.4 drill driver? I just need to see how the gearbox goes back together. A small backstory why will follow, but essentially I have a Wickes drill driver, that I had to take a part, but I have a spring that I can't work out where it goes. Any help would be great.
Items in the gear box, as far as I can tell are back in the correct place, however there is no clicking sound when changing the torque, and I have a regular spring that I don't know where it goes, it is not the big spring that goes outside of the gearbox and inside the torque setting part, nor is it a leaf spring. Why didn't I record where each part went when taking the gearbox apart? I stupidly half dropped the gearbox so the parts fell out.
Backstory
The chuck on the drill basically decided to break on me, to the point that it would not unstick to unscrew it, I spent over a week trying different things to open it, but in the end I said, I will go through the gearbox and use heat if needed and I will use the vice, with leverage. I had a few feet of leverage and the chuck shaft in the vice, I managed to get it off.
Main problem/current setup/bad setup
The shaft of the drill, I have the baring on the screw side for the chuck, goes into the plastic casing, then inside the plastic spacing, there is enough room for a spring and I can just get the second baring and washer pushed down into the case shaft, keeping it in place with a circlip. This is where I then add the gears of which I have a good idea on how they go back now. However the spring is now trapped and there appears to do nothing, especially without the spring there is no movements what's so ever. So, does this mean the spring goes inside with the gears? putting pressure on the system to allow for high and low setting or reverse?
Do you have any experience with a spring inside the gearbox of a drill?
Backstory
