Wickes combi 102 (Halstead)
11 Dec 2006
Middlesex
Hi all,
The boilers a Wickes combi 102 (Halstead)-
Replaced- PCB, Gas valve, APS
Burner only lights when combustion chamber is completely off!
Flu is clean, venturi tubes clean, ive got power to the fan (& is spinning in action)
Do you think its worth fitting new fan?? Just maybe guessing that the RPM of fan has reduced and so is ineffective!!??
If anyones come across this before or got any ideas, would be much appreciated.
ThanQ
The problem is he could have bought a new boiler from what he has spent so far :LOL:
Did you put the tubes on the right way round when you changed the APS
or
Did you check that the wires are right according to how you took them off
Sometimes very similar looking items can be wired differently inside. There is usually a little wiring diagram on the APS to show how it works.
They do a similar thing with some built in combi timers to make peoples lifes hard and make sure that they only use genuine parts at a rip off price
Problem is burner only lights when combustion chamber is completely taken off.
Checked all tubes and wiring and all is fine!
Any other ideas??
Much appreciated
All these parts are combustion and safety related and I dont give advice on DIY work on them unless I am totally confident that the owner is CORGi registered or equally competent.
Tony
if the boiler only fires up when the combustion chamber lid is off then i would look at the flue for blockages, check the fan venturi for blockages . it is quite possible if all the above checkout ok then the fan or aps may need replacing.
