Wickes LW 50ci
13 Dec 2008
Wiltshire
I have a wickes lw 50ci, The overheat LED is not illuminated, I've got 1Vdc at the ignition control connection and it still doesn't seem to have solved my problem. Can anyone please offer me some advice? thank you.
Problem is that the boiler is sending power to the pump, But the fan isnt running and respectivly we have no ignition or actual operation within the boiler.
Assuming that this is a conventional or condensing fan flued combi boiler as opposed to a premix burner.
Is there a call for heat. ?
Does the fan run?
From the little info I have here I suspect a faulty fan relay on the pcb or a faulty fan
I can't find any info online about your model.
Perhaps you could post a pic or point us to the Manufacturers instructions? i got as far as This Link
at the top of the forum:
read: read this before you post
it may help to help you
