I'd be really grateful from some expert advice from the pros here. Over the last few days, I've put 3 coats of matt white Wickes vinyl matt emulsion on the ceiling, and two of the same but coloured on the walls. Even after three coats, the ceiling is patchy, but better than it was after two coats. I loaded the roller properly, and applied it as I usually would. The walls I used a large brush, and after two coats, they are quite patchy and you can see where the brush has been in lots of places. Also with the walls, you can still see the original colour underneath slightly - emulsion seems a bit thin.
Is my problem;
A) Wickes vinyl matt is crap
B) I'm crap at decorating, although I've emulsioned a number of ceilings and walls over the years without problems
C) Because it was 26 degrees C in the room when it was decorated.
Grateful for any views, as I'm at a loss.
Is my problem;
