Wickes wooden flooring
I
imamartian
i'm about to purchase wooden flooring for my lounge, and have done a bit of research, and i see i could have laminate, engineered, or real wood.. well i've decided engineered will be right for me.
and then the Wickes adverts... 30% off.. sounds great except when i go on their site, they only seem to be selling laminate or real wood... am i missing something? or are they really not selling engineered boards in their sale?
Any advice appreciated...
I just had a quick look at the Wickes site, and I think the engineered wood you are after is listed under Real Wood, rather than the Solid Wood flooring.
If you look at the descriptions of the particular wood flooring you're after, you'll see it says how it's constructed, whether it's a solid wood or it has a wood veneer.
Hope it helps
Hope it helps
thanks my friend, my kneejerk reaction was obviously unneccesary..
laminate floor is a photograph of wood stuck on some chipboard type arrangement.
engineered by design i guess is laminate, as its bits of ply laminated together with a veneer of real wood like oak on the top. But its called engineered floor to avoid confusing it with laminate
the diference would be obvious if you had them in your hand or under foot, but if you were looking in a catalogue they would look the same. I guess its just the names people have adopted for the different products.
the difference is:
real wood = a lump of wood you can sand and varnish until it's gone.. it acts like a piece of wood in moist v dry conditions etc
engineered = a thin piece of wood, so it can be sanded a few times, but is stuck to other things to avoid movement in moist or dry conditions
laminate = a piece of paper (looking like wood) stuck on an inert timber substitute like mdf to reduce movement etc, and can't be sanded at all !!
real wood, better known as solid wood: can be sanded as far as the T&G only ;)
wood-engineered: at least 2mm solid top layer of real wood
wood-veneer: max 2mm solid top layer (but standard 0.6mm solid top layer) of real wood
