I am building a rear single storey extension and my wife now thinks that the existing kitchen window opening (which i will eventually remove and and cut to floor level) needs making wider so to let more light in.
The house is brick outer, block inner with 50mm cavity.
There is a concrete lintel over the current opening but she wants me to make it about 1mtr wider (one side only, not 500mm each side).
The upstairs joists run inline with the house walls so i am sure that the wall i want to open up is not supporting the joists.
Basically.....do i HAVE to use acro's / strong boys or can i just knock away the wall above the current lintel and make good any fallen / disturbed masonry after inserting the new lintel.?
If the advice is to use supports (which i'm sure it will be)...how much are these to hire and whats the key points on using them.?
