Not sure if this is the correct section so feel free to move.
The house I'm moving into has a Purple concrete brick block driveway. the width of this drive way and between the gateposts is 220cm and the width of my car is 210ish with the mirrors out. anyway its a very tight squeeze and although i can manage it with much care, i don't fancy doing it day in day out or the Mrs's chances, as she may have a little bit of history with posts and cars in car parks....
So the plan is to knock the gatepost down and move it (before the mrs's does it for me ) and widen the drive.
To the side of the drive toward next door, there is more than a meter of space which is currently occupied by bushes and plants. so plenty of room for expansion. also there are plenty of the same bricks behind and to the side of the house that i can pull up to match. so i should have lots of available bricks.
The existing driveway is not very level and has dropped in places, so im guessing it was done on the cheap.
Its more likely that im going to take up the entire driveway and start again, does anyone know of any good guides to doing this, and any rough costs for things like hardcore and such.
i thinking ill cement the kerb stones in first and work to them, I assume i put the hardcore down first and then cement the kerbstones to them? I should be able to get a slight angle down the drive to the road for water run off, anything else to think about?
thanks
thanks
