We have a conventional system with a water tank in the loft and a cylinder in the bathroom. Cold water has good pressure but the hot water in the bathroom is quite low.
I have talked to a plumber about fitting a pump to our cylinder to increase the hot water pressure, but before i do that i just want to check if maybe a shower attachment would work without the pump?
I have previously tried a plastic shower attachment but the water was sprinkly at head height, but i have heard that if i get a hose with a wider bore then it would increase the pressure a bit.
Would this work? or do i need to measure my hot water pressure first?
To be honest i cant remember how wide the plastic one was but im assuming it was a bit thin.
