About 5 years ago I had my PCB replaced on my Potterton Suprima 50 boiler because it kept on cutting out & eventually got the red flashing light.
The PCB model was 5102160 & I sourced it myself (saved lots £) & got my fully qualified friend to fit it.
However, I'm now getting another problem. Sometimes, when my boiler switches on, the fan starts but never actually tries to light, there's no ignition signal being sent. Eventually, it seems that the boiler 'times out' & the flashing red light comes on - however - the boiler doesn't cut-out, & the fan carries on spinning. Sometimes, I have to reset the boiler 5 or so times for it to ignite, but once it ignites the boiler stays on & doesn't cut-out again. The problem doesn't happen all the time, but it does seem to be getting worse.
So, does this sound like another PCB fault? If so, instead of just replacing the PCB, could I get the Upgrade kit Part No. 5111603? Its only a bit more than a replacement PCB. But I cannot find any reference to it replacing boilers with my PCB model No. (5102160) only ones with a 407750 PCB.
So, does anyone know if the Update kit will work with my boiler & is it worth getting over just the PCB on its own? (is it more reliable, etc)
Thanks.
Thanks.
