I'm about to install a Techflow QT45-2 shower pump, and i'm concerned about the possibility of getting an airlock in the pipework run from the pump to the bath/shower mixer taps. It's all installed in the airing cupboard, the pump, CWS and HWC. The feed from the CWS will be direct downward 22mm, and the hot feed from the HWC via the 22mm 'Techflange' which is a new direct connection to the hot tank. Thing is, the pipework which goes from the pump to the taps, firstly it goes up from the pump about 10 inches (via the flexi hoses), then it has to go down about 15 inches to below floorboard level, in order to go under the floor to get to the bath/shower mixer tap where it obviously rises back up again. Does anybody think it would cause an airlock at the highest part? The alternative would be to run the pipework at the same height from where it leaves the flexi hoses, but that would mean running copper around my bathroom walls 1.5 feet off the ground, extremely ugly!!
Thanks for any advice!
