Hi recently I took out a wall, door and window in order to do a knock through into an extension. Directly above the wall is a lintel that runs along the entire length of the property. The property is part of a terrace of properties (around 8 houses). The lintel runs continuesly along all properties and seems to be one piece.
The lintel is about 45cm wide and 40 cm high. Length is around 80m as it runs along the entire terrace of properties. The opening that was created is about 3m wide. My builder inspected the building and said we will not need any support as the lintel in concrete and there are no joins in it, it runs along the entire property.
My question is, is he right? and will the lintel hold the first floor above (floor above is floorboards)? Thank you.
