Hi, An old cistern (at least 10 years) has been moved and fitted without the overflow being connected! Not by me of course!
I am looking for the best way of resolving this. Fitting a 'normal' outlet pipe through the wall is not possible.
As I understand it, the modern syphon (with internal overflow) is not designed to cope with the larger quantity of water (7.5 or 9 litres I am told) in an old cistern. The result being that the equally old toilet bowl may not be successfully flushed. Is this correct?
If there is a risk that this is so, would a "flapper" valve, such as the "Fluidmaster" flapper valve, be a solution?
If neither of these I guess I will have to revert to plan A which was to connect the overflow to the foul pipe via a one-way valve.
All comments, advice etc will be gratefully received!
