Hello
I have an old Wylex fuse box with wired fuses and am considering having it upgraded to a modern unit. The only bonding on the existing box is to the gas pipe which is a short distance away.
Will an electrician also want to bond the new consumer unit to the water or other pipes?
The water pipe goes into the back of the house and the fusebox is at the front. So running an earth cable between the two would be a big job.
Thanks for your advice.
