- Joined
- 1 Sep 2003
- Messages
- 82
- Reaction score
- 0
- Country
No, it isn't complicted. However, I would state again that I cannot condone or recommend it. Rather than me just be Mr Whingebag, please let me explain why:
I appreciate you want to save the money, but as a professional electrician, I would be very concerned at anyone who is not qualified working on a main cutout. There is a 100Amp fuse in that cutout, and should anything be shortcircuited between there and the meter/consumer unit, I have seen the bang it makes - thousands of amps will flow for a split second before that 100A fuse pops - it once blew the entire end off my pliers (even pros make mistakes!). Should the incoming side of the cutout be shorted out, it doesn't bear thinking about. It only takes a dropped tool or slipped screwdriver to cause a big bang. Also when you pull the cutout and remove the cover to connect your tails, the incoming side will still be live and exposed.
Sorry to be a downer - I appreciate this site is designed to encourage DIY, but there are areas of electrics that I do not believe should ever be carried out by DIY'ers. The board's main fuse and metering is one area that could be extremely dangerous if anything goes wrong, as there is no margin for error, and little protection from a major short-circuit. I appreciate it looks very simple, but I have seen many dangerous things over the years - there is a reason why we do a four year apprenticeship, one of which is because it makes us understand and respect the possible danger!
I would consider booking an NIC sparks to do this purely because he can check that everything is OK before connecting the tails. I appreciate you want to save the money, but this should still work out cheaper than if you got a sparks to change the board in the first place. You'll have the satisfaction of knowing you did the job, and the confidence that all os OK.
Sorry to be unhelpful, but I do have a conscience, and there is a limit to what even a competent DIYer should tackle! Please consider this carefully, and make the right (safe) decision.
Take care
Paul
Take care
Paul
