Will this work? Toilet cistern fitting
5 Dec 2012
I am fitting my new toilet. The 300mm tap pipe (pictured with isolation valve) is 30mm short to the toilet cistern. I don't really want to get a 500mm pipe as there will beloads spare making it a mess.
If I cut the pipe 30mm ABOVE the isolation valve that is in place already, and fit one of these http://www.toolstation.com/shop/Plu...WRAS Flexible Tap Connector/d20/sd2807/p71894 (will return the current pipe with isolation valve that I have) will this work? I've never done plumbing but it looks straight forward.
Is it a case of just cutting the pipe and screwing the thread of the flexible tap connector over the end?
Yes its as simple as you just said,no point returning the fexi hose you already have bought. Just use it
