I have an immersion heater thats not working. Its called a willis type thats situated on the outside of the hot water cylinder, and i would like to test if its the power to the switch thats at fault. The switch is the fused connection type with the neon light. Can i test it with a phase tester or do i need a mutimeter. I heard you have to be very carful when doing this. Also is the fact that the red light is off an indication of no power going to the switch,or could it be that the immersion element blew the fuse when it went. Thanku for any advice.
