I'm sure many of you will approve of this as much as I, but will they get anywhere?
http://www.epaw.org/media.php?lang=en&article=pr45
http://www.epaw.org/media.php?lang=en&article=pr45[/QUOTE]
I believe that's a definite yes...
... when we get out of the EU or it collapses completely.
If one removes energy from wind, it's really inevitable that it will slow. What I don't know is the extent to which thatvwill affect weather and climate, but it surely must have some effect if the amount of energy extracted is large enough.As to reducing the speed of wind I don't know but on the Seven there was a trial wave power and the reduction in energy caused it all to silt up.
I guess that depends upon what you mean by an entity. Wind has energy since it consists of molecules (which have mass) moving at speed. When one extracts energy with a wind turbine, the mass of the molecules doesn't change, so their velocity must fall. The turbine will also result in the pressure being different on the two sides (think aircraft propeller).Well, I'm only surmising but as the wind is not an entity in itself but is caused by pressure differences in the atmosphere I would think that any 'wind' slowed, or removed, by the windmill, if indeed it is, would have to be 'compensated for' in order to continue the process of equalising the pressure between low and high pressure 'areas' (volumes?).
That's the question I'm asking. I know that it will have an effect, I don't know how significant it would be.Is the energy removed so small it is negligible?
It's similar to the 'under' type of waterwheel, but I think they are much less common than 'over' onesIt is similar to water-wheel, isn't it, ...
Dramatically so, yes (if it's an 'under' type of wheel' - just as wave generators considerably reduce the waves beyond them. You obvioulsly don't get energy 'for nothing' - you merely shift it from moving molecules in air or water (by slowing down their movement) into electricity. 'Over' waterwheels, or the turbines in hydroelectric plants, are more complicated, since gravity (hence loss of potential energy as the water falls) is a major part of the equation.Does the wheel slow the flow of the water?
I should have added ... have you not come across the phrase "as still as a mill pond"? The water will appoach the watermill's wheel at a fair rate of knots, but once it has passed the wheel (and had the energy extracted), there's often virtually no movement/flow at all.Dramatically so, yes (if it's an 'under' type of wheel' - just as wave generators considerably reduce the waves beyond them.Does the wheel slow the flow of the water?
I've just done a little Googling of the general topic of the effect of wind turbines on wind, weather and climate. It is clearly a complex and controversial topic, which is currently undergoing consdierable research. Most seem to agree that it has some effect on local weather and that, if wind turbines became far more prevalent, this could have global implications - but most (but not all) seem to feel that the envirronmetal downsides of wind turbines are outweighed by the environmental advantages. It also appears that the mixing (of upper and lower layers of air, with different moisture contents), due to turbulence created by turbines, is a more important reason for weather/climate changes than is the effect on winds.The wind (air) only has energy because of the high pressure forcing it to the low pressure.
