I have discovered an area of rot on the exterior window cill on my period 1930s windows.
It seems to only cover a small section. I do not think it penetrates that deep into the wood.
When I tap it hard with the plastic handle of a screwdriver it sounds solid. However, when jabbing with the sharp end it sinks in a bit and the wood appears a bit soft.
What is considered the best long term repair option.
1. To cut out the rot and fill with external wood filler, if the area is small?
or
2. To cut out the rot and splice in a new section of timber?
I actually have period timber I reclaimed off my neighbours wooden windows. So it will be of the same age.
Based on that, would 2. be a better option? What are the issues with either solution?
Out of interest, is there a size issue with splicing in timber? Or can small sections be repaired with a splice? In addition, how is the splice joined with new and old; some exterior grade glue?
Many Thanks!
or
Many Thanks!
