Hello! I had some new windows fitted recently and noticed that on one frame, one of the screws fixing the frame to the wall is spinning and won't tighten. Is there an easy way to refix it to the brick work without removing the frame or drilling a new hole?
It feels like it's fine as it's only one loose screw out of the ones I can see, not like the frame will fall out - but just thought I'd check and see if there is an easy solution!
