Window in a single block wall shed plan
4 Jun 2024
I've been thinking about how to fit a window and door in a shed wall and I just wanted to check if the following plan sounds reasonable.
I'm building a single skin (100mm) block front wall to my shed which will have a doorway and a window in it. The front wall void is 3000 wide and I have been donated a window measuring 1490 wide. The plan is:
225 pier - 1490 window - 225 pier - doorway - 225 pier
The piers at each end will also be mortared to existing prefabricated 35mm thick concrete walls. The wall under the window (3 courses) will be mostly single skin. The door will be homemade out of timber, effectively a barn door, so quite light and will be hinged on the end pier. The were will be a wooden beam spanning full width above window and door, this will not be load bearing, but metal roof sheets will attach to it.
