Hi all,
I had a new VEKA window fitted by a joiner roughly one year ago who I can no longer get in contact with. The window appears to be leaking, at first it was insinuated that it was the flat roof that was causing the leak. However, after hiring a roofer and spending at least 6 months, back and forward trying many different ways to track the leak. We got to the bottom of it. We made a hole on the internal plaster and tried different methods and areas of pouring water down until we found the leak and it appears to be coming in when water is poured down the inside of the window, down the drainage holes.
The water does drain but it looks as if the water also travels to the corner of the sill and out the bottom corner. (see picture, this is NOT my window but one I've taken from Google as it looks identical to mines.)
Picture linked here - https://ibb.co/f3deg5
If I look close enough, I can also see water in the channel. At first glance, I suspect the sealing has a hole or should there be end caps here, flush with the wall to prevent? I can't tell what is there as the window is pretty tightly fitted.
As I can no longer get in contact with the fitter. Does anyone else have advice on what I can do? I don't want to purchase a new window as I suspect VEKA have a 10 year guarantee (as per there website) but I don't have any paperwork to prove this, except the serials on the inside of the frame. Would another fitter be able to track the serial and get a new replacement should it be deemed faulty?
Any advice would be greatly appreciated.
Thanks.
Thanks.
