Hi there,
Right, I'm replacing an 800mm wide floor length window with a conventional height (1000mm), but wider (1200mm) one, so this will have to include widening the lintel. Existing lintel is a 250mm thick by 100mm concrete beast bridging the cavity. I'm proposing to replace with standard 100x70 lintels in each leaf 1500mm long to give 150mm bearing either side of the new window. Basically I want to know if this is OK, as of course BC will be having a look. My question is, is this builder's rule-of-thumb territory, or a job for a SE?
If some details would help, the wall in question is the rear elevation of my Bungalow. It's part of an extension to the rear of the original build which was initially flat-roofed, so a few courses above the window are timber joists in hangers supporting ply and felt. At some stage a shallow pitched roof has been plopped on top of the old flat roof (which remains) so a gable (about 5-6 blocks high at the centre) has been added to this wall. Whole lot - the extension and later pitched roof addon is leightweight block rendered to the outside. I'll have to re-render where the lintel is altered, hence I dont mind a concrete lintel showing. Window is about a third along this wall so is not under the full ridge height of the gable wall.
Any advice on whether my proposed lintel spec is OK would be much appreciated, or whether this really needs to be backed up by SE calcs (BC haven't suggested they'll be asking for any). Oh and one last thing - I was looking in Wickes as they're local. Is it true their 100x70 lintels 'snap like carrots' as I read on here whilst searching?! I have a Travvy-P and a Jewsons local, too. Better bet?
Cheers,
Liam
Cheers,
Liam
