Window Opening in Timber Frame
4 Jan 2006
Devon
OK so I am finishing off my timber frame for my garden workshop (project here).
I have fitted the noggins and want to get the frame up onto the block walls (its a part block part wood construction).
In the frame that my window is going in I have just moved the two central common studs out so I can fit Jack Studs for the window sill plate and header plate.
Problem - I haven't got my window sill yet (either UPVC or wood not decide) so I am unsure exactly where to fit my sill and header plate. I was trying to fit them whilst the frame was off of the wall so that I can fix the jack studs from underneath with screws.
Would it be ok to fit the frame to the wall minus the Jack studs and winds plates and fit them afterwards by scewing screws in from the top? The two main Jack studs can be screwed to the adjoining common studs I gues.
I am referring to this for names and ideas.
Also - do I fit the breathable membrane before fitting the window. e.g. wrap it around the window trimmer studs, header and footer to for a nice seal before the window goes in?
You can fit in any order , the site you reference is in US so terminology is not the same as UK.
