is there a wall cavity and is it insulated?
My preferred method would be to insulate the open cavity, dot/dab the window reveals, basecoat damaged areas, then bead and scim.
For the top of the reveal I'm going to double up some sheets, what is the best way to bond them together? Is the plasterboard adhesive used to bond it to the wall OK?
