I have fixed{dot + dabbed} 60mm insulated plasterboard to single hollow block wall,and I am about to set the anglebeads and insulate around the two window reveals.The depth of reveal is 120mm(70mm p/b and bonding,50mm concrete block].My problem is I only have room for 1 cm of insulation before sk.imming -any more and the window frames will start to disapear.I was thinking of slicing 25mm foil backed kingspan down the middleand sticking them up with something that would adhere and seal the two diferent surfaces[waterproof adhesive?]-then skimming over exposed sawn kingspan.....Is this a good/silly idea?...i would welcome any advice .
