Window sides not vertical
11 Jan 2013
Durham
Solid wall, full brick. The outside of the window is about half a brick smaller than the inside (left, right and top). Width is 910, sides aren't vertical (about 20mm out at the top).
New window is going behind the front face.
Question- which will look better- 950 wide (so 30mm of frame will be behind brickwork top left and bottom right) or 920 plus 20mm fillers each side (so only 10mm of frame will be hidden but bottom left and top right there'll be about 90mm of frame plus filler visible with 60mm at the other 2 corners.
Ta
