Window sill heights for toughened glass new build?
4 Jan 2009
True North
In a new build, how high do the window sills need to be from the finished floor level to avoid needing toughened or laminated glass?
Where is the measurement taken from, is it from the finished concrete floor height or weyrock board to the top of the window sill, the actual glass in the frame or something else?
800mm from the finished floor level where the glazing is exposed, unless in or within 300mm of a door then its 1500mm
So it's from the finished floor height to the actual glass, not the window sill? Looking at my own windows the glazing sits 120mm higher than the inside window sill. I have 120mm of frame & sash.
Thats correct
Do you know what the maximum window sill height is. I keep reading 1100mm max which is mainly for bathrooms and kitchens, but it doesn't say if it's 1100mm to the lowest part of the opening or whether it means to the top of the inside sill.
To keep inline with brick courses the window opening was going to be 975 or 1050mm. 975mm isn't high enough for the kitchen because the UFH screen will be around 60mm thick, then 910-930mm finished worktop height.
1050mm window size height seems best, and 1050mm of the floor which comes inline with the 2100 lintel heights of the doors.
Maximum height in terms of what... fittings/worktops or BR’s?
Using a nominal 2.1m from external DPC to window/door heads, then it’s common to have 1050mm deep windows to Kitchens/Bathrooms, etc... and 1200mm deep windows elsewhere.
There is maximum height of 1100mm to escape windows under B regs, but this only relates to the escape window opening, not cill heights
I've seen a few times mentioning theres a maximum height of 1100mm for the lowest part of a window, don't know if this is for the lowest part of the brickwork window opening, or if it means to the actual upvc sash opening lowest point for escape regs?
1200 deep would mean an internal sill height of 900mm, that seems very high for what i'm used to in a living room or bedroom, the glazing would be over 1m
This is to the lower part of the opening and only to windows used for escape and does not relate to the cill
Well lower the cill then and have more glazing :confused: Bear in mind you start getting to near to the ‘critical locations’ regulations.
Are all windows classed as escape windows if they are the only window in the room?
Has uni started already?
Is this short for something or sarcasm?
What are critical locations? An architect suggested 1350mm deep window openings.
This would depend on a number of factors, but as a very general rule above ground level to habitable rooms unless there is a protected stair or to inner rooms on the ground floor.
The critical locations are in the diagram I've previously posted. No idea where he's got 1350mm though.
1350 was just the size an architect suggested instead of a 1200 high window.
1800 wide x 1350mm height of the window opening with cill height just over 800 internally.
You have mentioned ‘an architect’ a couple of times now and the questions you are asking are those an architect should know. What are you actually trying to find out or achieve?
Btw, you are aware the sizes the architect has mentioned are basically ‘structural‘ opening sizes including the frames so therefore not the size of your actual glazed area?
Having a read of the BR’s in particular ADB and ADK will answer most of your questions.
