I have two upvc bay windows fitted in my house, one upstairs and one downstairs . The vertical side trims on both,fitted to bridge the gap between where the window ends and the wall, are causing cold spots and mould due I suspect to having no foam having been injected. Is there any way of injecting foam without removing these trims as I've tried and they're stuck fast and threatening to crack or break. The only way I can think of is to drill a hole in the trims,either inside or outside,and then injecting the foam. Or is that a bodge way of doing it?
