As part of a bathroom refit I am removing the window and boarding (apparently fitted by Bob the builder's less competent brother using all sorts of scrap material).
Question is (I haven't fully disassembled so bear with me) ...
The cavity appears to be fully open and the window (pvcu) appears to be screwed to a board bridging the gap [plus some 'interesting' packing/botching) - I think that the screws from the window frame are in line with the cavity (i.e. no direct fixing to brick available). I would like to reduce the depth of the ingoe boarding so that I can tile deeper and am looking for pointers on the best way to close the cavity and allow a fixing.
Two options that spring to mind:
1) Insert bricks to close cavity using DPC vertically to avoid bridging and fix window directly to that;
2) Fix plate over cavity (presumably with dpc around to avoid bridging) and fix to that ... I can fix lath so I can tile to it;
3) I saw a detail on the web where a timber fill had been used in place of the brick in option 1 ... unclear how it was fixed although I suspect a big hammer. There was no dpc shown which was slightly surprising.
Preferred option is one that allows me to minimise boarding back into the bathroom (i.e. 1 and 3).
Anyone got any better ideas; dire warnings of doom or advice on detailing?
Any help appreciated.
EDIT>
The detail noted in (3) above is at http://masonryjobs.net/design_tools/masonry_details/details/01_402_2D.php
EDIT>
