Windows - Damp after removing side strips & plastering
29 Oct 2013
Cheshire
(re-posted, I'd put this in building section)
Need some advice here.
While re-decorating I removed the plastic side strips from the plastic d/g windows & plastered right up to the window.
Now I have damp patches in the bottom corners of both windows so I guess I did something wrong.
Looking at the windows after removing the strips, I could see approx. 20mm of the outer brickwork then the dpc, there is no gap to speak of, the inner brickwork is turned to butt up to the dpc.
I am thinking now that the damp is tracking through. Although it is only showing damp at the bottom corners & not higher up the window.
I have re-siliconed the outside of the windows.
Can anybody please help with some advice?
I have searched & found similar posts but with nobody saying thanks that solved it, just left open?
Edit: forgot to mention, This is much worse with wind driven rain. (We live top of a hill)
Regards
Russ
Read more: //www.diynot.com/diy/threads/w...-side-strips-plastering.421169/#ixzz3M8fgwiG3
If the plaster is bridging the DPC and touching the outer brick skin then yes it will just soak up the moisture from outside.
Do you have any photos from when you took the trims off?
Hi Gazman, thanks for the reply.
No pics but definitely outer brick showing 20mm on inside, the plastic side trims covered this up. Maybe I should replace them but would prefer not to, it does look better plastered up.
Sounds like I'm going to have to dig out my plastering, but, how would I seal off that 20mm of brick to the dpc so I can re-plaster over it?
Thanks for any solution
Regards
Russ
You did nothing wrong except reveal the poor fit of the windows, the strip would have just hidden the fact moisture getting in where as filling the gap reveals it.
Possibly foaming the gap then plastering over might work, or if you could push some dpc between the frame and that 20mm of brick showing and then fold it into the cavity, this should stop the water from wicking from the brick to the reveal
Hey, thanks for the replies,
I got some expanding foam, if I fill the gap with that will it be ok or will the damp track across the foam?
Regards
Russ
Cured foam is waterproof so you should be alright on that score
Thanks crank, So bridging the dpc is ok.
I dunno what "cured" foam is? I got this expanding foam from B&Q for a tenner, is that same? sounds scary stuff like it could fill the room & suffocate us.
I shall give it a careful go in the morning, thanks for the advice.
Regards
Russ
Don't worry there isn't enough foam in the can to fill the room, so long as you don't squirt it down your mouth I'm pretty sure you won't suffocate.
I've gone with this plan. I siliconed the new dpc to the frame & the existing vertical dpc. The foam can does say it doesn't bond to silicone but there's enough other stuff for it to stick to (hopefully).
I shall post later to let you know if it's been successful, have to wait until I've finish plastered & then a good wind driven rain to be sure.
Thanks to all for your input to date.
That plan seems to have worked ok. I've sent the missus up to re-paint the job.
Thanks to all for your help.
