I have received two slightly contradicting statements from window suppliers when I asked how tight the window frames fit into the window openings. One supplier said that they typically size them 10mm narrower and another supplier said that they size them down to the mm and there are practically no visible gaps to be filled in.
I lean towards the latter, ie make the window as close fit as practically possible, because a 5mm gap (5+5) appears too much, is this correct?
