Am in the process of getting my garage into a usable state and I need to seal around the garage doors - the doors are up and over aluminium/steel type doors.
I have found weather strips for the bottom of the door online and in the DIY chains for around £15 for a 2.5m strip which attaches to the outside of the door but I also need to seal the sides as there are gaps and a lot of wind comes in through them.
I found some 3mm x 50mm rubber strip online which looks ideal. Could I use that attached to the frame on the inside with self tappers to create a seal down the sides?
I know I wouldn't be able to go all the way to the top as when the door opens it hinges down but I cant think of any other way of doing it. Are there kits for sealing the sides or other ways I haven't thought about?
Jason
Jason
