- Joined
- 1 Sep 2015
- Messages
- 371
- Reaction score
- 6
- Country
Just want to check my logic here.
I've got some LED strips I'm fitting. Max pull is at 48W at 5V, so requires 10A. I've got a Meanwell 200W 5V 40A PSU, so plenty.
The LEDs though require power at both ends as they're addressable, so 5A to each end.
So using this site, I'll probably have about a 7 meter run to the end, and a 3 meter run to the start.
By my calculation, with 10% voltage drop, I need a 2.5mm2 wire for the end, however obviously that's not something I can solder to an led strip.
Can I connect this 2.5mm2 wire to a 0.5mm2 wire that's about 10cm long and wire that to an LED?
In my head, it seems wrong, but it's a short 10cm 5a run, and according to that site, that's what you'd use?
Voltage Drop Calculator
Wire / cable voltage drop calculator and how to calculate.
www.rapidtables.com
