I'm going to fit a Honeywell wired programmer stat to replace the rubbish wireless programmer and stat the boiler came with.
It is a WB Junior combi boiler.
To minimise the amount of channeling in the wall I have to do (it is a 60's build and uses concrete blocks!), what is minimum spec of cable I can use from boiler to control? Twin and Earth seems a bit overkill as the cable only carries a switching voltage/current (or does it?).
Any advice gratefully received.
