Wireless CCTV advice
3 Dec 2011
Yorkshire
I'm thinking of getting a Y-Cam wireless CCTV camera to mount on my garage and look at the back of my house - specifically the patio door.
If I get an outdoor camera it'll be vulnerable as the garage isn't very high.
I was thinking of getting an indoor camera, cutting a hole in the wall of the concrete garage with an angle grinder and mounting the camera behind a sheet of laminated glass.
There's a big floodlight that would light up anyone who enters the area so I don't think I'm going to be very reliant on the infrared capabilities of the camera but I'm wondering if me putting the camera behind glass will cause any issues?
Maybe it would be better to get an outdoor camera and mount it so it's mostly protected and disguised but not behind glass?
Only things that come to mind are if it is a PIR camera it will not operate through glass and you might get condensation on the glass if the garage is prone to it, or wet cars, mowers are put away in there.
A favourite way of disabling cameras is a quick spray from a paint can. Unfortunately your laminated glass will not protect from that.
Can you not mount a dome camera, bit less prone to tampering bar being sprayed of course.
Just a thought you can get infrared floodlights or external IR lighting if you want a more stealth approach to illuminating the scum.
