I recently installed a 2N IP door station at a gate and I'd like to provide a simple "Ding-Dong" inside the house to notify when someone rings the gate station button. My home automation system will send push notifications to phones and tablets but it's still nice to have an audible notice.
My thought was to get a wireless doorbell, solder wires onto the terminals of the mini push button switch of the transmitter and attach those to the relay outputs of my home automation system.
It works, when the relay closes, the chimes ring. GREAT! BUT the problem is that when the relay opens, the chime keeps ringing. If I put my voltmeter across the terminals of the relay I see that they close and open properly so why would the chime keep going?
Coincidentally, when I put the voltmeter across the terminals of the relay, the ringing stops.
The doorbell transmitter is powered by a 3V CR2032 battery.
Is there possibly some residual current passing through the relay even when it's open? Is there a minimum spec. on what can be connected to the relay outputs?
Any thoughts or suggestions would be appreciated.
