Wireless programmable thermostat to multiple receivers ?
2 Apr 2007
I've searched the forum and wiki but failed to come up with any answers to my question.
I've a very large room where the heating design was less than ideal, in that it is heated by 3 x Myson Slim-Line wall heaters, working off their internal thermostats. The heating zone is shared with 2 bedrooms, each of which has TRV controlled wall mounted convector radiators.
This means that when we want to heat the bedrooms, we've no choice but to heat the large room as well, unless we manually turn down the thermostats on each of the 3 wall heaters, and then turn them back up again when heat is needed. The bedrooms are less of an issue vice versa, as demand can be controlled via the TRVs, and heat is usually required in those rooms for longer periods than in the large room.
The wall heaters have the ability to be controlled by a remote thermostat. Given the type of construction, and size of the room, wiring into the heaters from a wired thermostat will be difficult, disruptive and costly. Ideally I'd like to use a programmable wireless thermostat that will control 3 receivers simultaneously. Are the forum members aware of such a system ?
Thanks for your help.
Have not heard of a unit to do this i'm afraid,
are the convectors fed electrically by their own Radial Circuit, if so it may be possible to wire a single remote reciever to switch the mains feed to all three convectors (they have a very low electrical rating so should not cause a problem to the Wireless set up) :wink:
