Hello,
My Grannies boiler is a Vaillant turboMAX combination boiler.
All the radiators have TRV's on them which results in the boiler cycling quite a bit.
We need to get a wireless room thermostat fitted, we don't want to fit a programmable type because Granny is after a simple solution and is happy with the built in timer.
Recommendations please.
Also the radiators on the system are huge and the flow temperature needs to be set at a maximum of 55 degrees on the coldest days, doesn't this case the boiler to condense when it's not supposed to?
