- Joined
- 13 Jun 2013
- Messages
- 29
- Reaction score
- 3
- Country
I have a back boiled with hot water tank etc and the wired thermostat is on the first floor. These are the thermostat and controller at the moment
With cover off
Controller
As per my other posts I am getting a power flush plus some new radiators fitted.
All the up stairs radiators have Honeywell TRVs on them but even with these set low the thermostat is probably in the wrong place as it would only turn off the heating when the hot air reaches it from down stairs.
BG offered me one of the wifi/internet controllers for £199 but I reckon I don't need to have that and simple wifi one would do the trick and be cheaper.
So as I understand to connect this I would :
1. Fit the base/transmitter station to replace the existing fixed thermostat. I am happy wiring the new base unit but would like to know that this will be compatible with the existing power and thermostat wiring there at the moment ?
2. Turn my CH to constant
3. Continue to use my existing controller to set HW times on and off
4. The wireless thermostat could then be used anywhere in the house to control CH i.e. temp and settings for times on an off ?
In terms of units which would you recommend I am drawn to this one
http://www.ebay.co.uk/itm/HONEYWELL...arden_Hearing_Cooling_Air&hash=item20d51e9cc5
Would like one that will enable programming for 7 days i.e. be able to change it for weekends. Any others that you guys recommend ?
Finally I expect to change my system in a few years when it finally gives up, so will I be able to use this unit on a new combi ?
Regards
Jerry
With cover off
Controller
Regards
Jerry
